Teocalli04
Greetings: PICTURES ARE TWO MESSAGES BELOW
I have a open floor drain that is embedded in concrete and is for the mechanical room in case of problems.
I have moved a washing machine into this room and added a slop sink where the washer dumps into. Originally I created a "Y" off the floor drain and connected the sink to it but wound up with overflow and bubbles on the concrete floor because the house stack is six feet away.
For now I connected the sink PVC directly to the floor drain without the "Y" which works great but does not allow the floor drain to be used as intended of course.
Tying into the stack directly is problematic because it would create an obstacle in front of an adjacent room around two feet high across the space horizontal.
Thinking the solution is to create a new drain pipe for the washer flex hose, dig up the concrete and connect into the mid point of the floor drain branch line run which would allow for 3-4' before the floor drain which should be enough venting to eliminate any backflow onto the floor ?
Can anyone think of a novel way to tie into the floor drain without messing with the concrete ?
thanks,
Dave
thanks,
Dave
