tub shower combination - drain size
shaken-n-stirred
Jan 7, 2015
95
It seems like most tub shower combination units have 1 1/2 inch traps and 1 1.2 inch horizontal drain lines. Correct? Wrong?
However, the codes seems to state that a 1 1/2 inch drain is only good for ONE FIXTURE UNIT and a tub shower combination is TWO units.
So do I need a 2 inch drain?
If so, can I come down from the water and overflow, into a 1 1/2 inch trap and then step the drain line up at that point?
Confused.
Thanks
you use a 2'' ptrap with a 2x 1.5 bushing in the trap, making the stand pipe 1.2''
you mean 1 1/2 inch stand pipe? Not 1.2? And by stand pipe do you mean the length of pipe between the sanitee on the waste and overflow and the trap?
thanks
