Tub P-Trap in 6" floor joist?
Bogucki
May 10, 2012
57
Is there any possible way to fit a tub drain and p-trap into a 6" (5.5") floor joist?
This bath is on a second floor and the joists are only 5.5"s deep. I'd rather not have to fir down the ceiling in order to fit the plumbing in. I measured a 1.5" p-trap and it was 6" deep just by itself.
I guess my other option is to elevate the tub, which would probably be easier.
Is there any solution to this that I'm overlooking?
So like this? The main drain is actually back behind the tub, so it will span the distance of the floor joist.
I can use 1.5" for this right? Or do I have to use 2"?
Thanks John, will do. Just copied and pasted that one, but yes I will use a glued trap.
