Plumbing_Steve
I bought a property last year that I am now renting out. I don't have much experience with plumbing but I am learning quickly.
The tenant has phoned me up with the following:
- There is a leak from the master bathroom to the kitchen ceiling below.
- It's not a big leak. Just a small wet spot on the ceiling.
It appears to be timed with when they use the shower. When they use the shower, they notice it once every two to three times (why do they keep using the shower!) They are no longer using that shower.
Here is my plan when I arrive:
1) Touch the spot on the ceiling to see if it is wet. If it is, poke a nail into it to see if it is pooling above. If not, go upstairs. If it is pooling, cut it open.
2) Take the trim off the shower faucet. Operate the shower and attempt to see if there is any water leaking from the shower pipe or valve during operation.
3) Check the drain assembly in the shower pan to ensure it is properly sealed.
If none of those lead me to the problem, then I may need to cut open the kitchen ceiling.
One other possibility that comes to mind is that it may be a leaky roof with water following down the outside of the vent pipe.
House was built around 1988. Master bathroom was redone in the last decade.
Does this sound about right in terms of how to go about it?
Any other things you might look at or tools you might bring when trying to find a leak?
Thanks!
Thanks!
