Hi,
Great forum!
I have a 50 gallon GE Rheem electric water heater which was working fine until it started leaking from the THREADS of the Temperature/Pressure relief valve. I've tried to remove the TPR with liquid wrench and a large pipe wrench, even put heat on it with a propane torch, but it refuses to budge.
What would cause it to leak at the threads? A crack? Corrosion?
The water heater is at least 15 years old.
Is it possible to use a sealant around the threads to keep the water from leaking out, or is there too much pressure? I can see the threads so I can apply some sealant to them where they join the metal top of the tank.
If the sealant idea is no go, how can I get the TPR valve out to inspect it?
Thank you!
Great forum!
Thank you!
