Hi, and thank you in advance for any assistance or advice you may have to offer. I also want to preface this post by letting you know that I know absolutely nothing about plumbing.
I recently moved in to a condo that I purchased and in the past week I've had a slew of plumbing issues.
- toilet 1 never stopped running after flushing so I turned off the valve and waited, turned it back on and now it's working normally
- toilet 2 was stopped up for no apparent reason
- showered today while simultaneously doing a load of laundry in the washer and the drain backed up, then I noticed that the other shower had standing water in it and water had not been running in that unit
- tried to use a plunger on both showers and the drain sounded(?) clear, but I did get out some hair and debris... Showers eventually drained on their own, but I don't know how to go about fixing the problem or what the problem even is
- also, when using the plunger on the shower drain I noticed water coming out of the round metal fixture directly below the faucet, which I thought was strange... Posting link to video
https://goo.gl/photos/DsHroLhWyaAWfS1g8
Again, thank you in advance for any assistance you are able to offer. I would really like to avoid a high charge from a plumber, so any advice for work I can do myself would be greatly appreciated.
