Bill0226
Honeywell WV8840B1042 gas valve; Whirlpool N40T61-343 water heater
Heater went cold, and controller indicated the two flashes for Thermopile Low Voltage.
After replacing thermopile which included the igniter and gas supply pipe, the pilot goes out immediately after releasing control knob. I get the same code two-flash code as before, Thermopile Low Voltage. However, checking thermopile leads with pilot on, I get 820 mvdc, i.e. within normal range. There are no drafts and air intakes are clean.
Why do I continue getting the same code, with a functioning thermopile?
