NorPlan
Active Member
. Hardness & Iron Content goes with the Neighborhood (Rural Setting).. My Query is the Number Strength on the little Thermometer they stuck in a Glass of Water (It Registered a #9)... Back in 2011 We switched to a different setup for Softening & Filtering the Drinking Water.. We have a UV Light , Heavy Duty Water Softener in that order, with a 7 Stage RO Filtering System tied into the Cold Water @ the Kitchen Sink for Drinking Water.. We were told at Installation the 3 Main RO Filters will have to be Replaced Once a Year and the other 4 Filters that sit Horizontally on top every 5 years.. Having followed that advice to date , this time being for all Filters to be Replaced at the sametime..
Looking for Opinions as the Tech said Not Necessary at this time to be Replacing Filters as his Pocket Size Thermometer registered a #9 from sitting in a Glass of Water.. I'm asking is that Good, Bad, or Indifferent ?? Prior to our Present Setup.. Whenever a Tech (Different Company) would make a House Call, No Two Techs gave the same Answer... Thoughts / Opinions Appreciated, Cheers Thanks
