boytonstu
Active Member
I decided to go forward with my $35 American Standard one piece lowboy.
Instead of installing it and testing it I decided to place it on 2x4's and test it out doors. It is easy to hand hold a garden hose in the inlet valve tube and see the exact point where it cuts off the flow.
Within a few seconds it was obvious that the inlet valve was shot. American standard charges over $150 for a replacement.
Well screw that option. I had a Fluidmaster available and it collapsed down to 9" height. So far so good.
I measured the height of the original water height and the Fluidmaster did not quite fill to that level.
Solution? I placed a lead anchor on a piece of copper rod taken from the old ball and the extra weight of the float raised the water level to the correct height.
I filled and flushed it several times and then tested the flush valve seal by waiting an hour to monitor the level. No leaks.
I had a problem with a broken PVC flange and installed a metal plate Tapcon screwed into the concrete.
Done! A beautiful toilet with inexpensive replacement parts, a quiet flush, and no leaks.
Not too shabby for a 72 year old.
