951Michael
Hello friendly plumbers,
I'm going to be installing a system that requires a drain located at least 5 feet from where it is installed, and the drain has to have at least a 2 L per minute capacity (1.5 inch drain pipe). I don't have a drain like this located near it, so I plan on installing a sump pump or something similar next to it. Do you guys have any good ideas as to what I should use for this i.e. what sump pump should I buy or if you have any other bright ideas please share. I suppose at its maximum output it could be as much as 2 L per minute. I plan on running the sump pump output to a 1 1/2 inch drain pipe that I will have to cut to accept it.
Thank you very much for your help.
