gmkaboulov
Apologies if this has already been discussed:
I am having issues with water hammer, and the combination of symptoms doesn't really match with anything I've read online about it.
Opening/closing a sink valve: no noise
Dishwasher: no noise
Toilets: no noise
Garden hose: no noise
Open bathtub valve: loud banging, stops immediately when valve is closed
Washer: loud banging
Sounds like air in the pipes, but this is where I get puzzled:
Toilet tank is filling (cold water only of course), and when I open only the hot water valve in my sink, loud banging. Closing valve immediately stops the noise.
No matter what combination, hot or cold, there is loud banging whenever more than one valve is open, except the dishwasher (I can open the sink valve while the dishwasher is running and there is no noise), and also the washing machine makes noise even if nothing else is open (but I am guessing this is because it opens the hot and cold supply at the same time). There is never any noise when closing a valve. Also the water flow visibly changes with the banging.
Is my house supply pressure too high or too low? Or is pressure even an issue? I want to eliminate some possible causes before calling a plumber. Thanks
Toilets: no noise
