Strange sound, can't figure out
dantheman22
May 6, 2024
Minneapolis, MN
A new water heater was installed a few months ago and I used Shark Bite water lines. The cold water line's valve did not close all the way and would let a little bit of water through, so I replaced just that cold water line/valve. After replacing, my water heater makes a funny noise only when the hot water is on. The more I turn on the hot water faucet the louder the sound gets. When I close the ball valve the sound does not happen. Please see video, it sounds like it's coming from the top of the water heater
  • IMG_2799.mov
    27.8 MB
It’s probably those flex lines. I’d replace those with hard copper or ignore it…
My 2nd guess but I highly doubt, could be heat traps in the inlet/outlet nipples.
Also I should note my gas is not on so nor is the heating element, because I'm not living there right now. But it was like that with the old lines
