Eric F.
I bought a condo three years ago. In January of this year, my water system stopped producing hot water adequately. I first noticed it from the shower. Then gradually from the remaining faucets in my unit. At first, the hot water would last about 10 to 15 minutes before running out. After about a week, I noticed a leak and called a plumber. The plumber said water was leaking from the water heater's tank, which was the source of the leak. Soon after, after getting two more opinions, I had the water heater replaced. The company that replaced it said the water temperature would return to normal after 2-3 hours. However, the water never returned to normal. After a about a week, I called another plumber to inspect the water heater and test the water. They suggested that something else could be drawing water from the piping in my unit. They said it is common in condos and apartments to see plumbing being shared by multiple units, and there could a leak somewhere else, or water was being siphoned off to another unit somewhere between the water heater and the faucets. I called my water company, and they came out to inspect the lines. They came out three times and shut off the water from the street. During each visit, I noticed a drastic improvement in the water flow throughout the unit. However, after each visit, water flow and the water temperature would gradually decrease, after varying amounts of time, ranging from 6 hours to only 30 minutes. Recently, I started shutting off the main water valve when I am not using water. After the valve is turned off, water will begin to flow into the water heater's tank, and the water heater immediately starts heating water. During this time, the water heater will shut off for a while and then start again. When I hear the water heater start a second or third time, I will turn on one of the faucets. And frequently, I see water running even when the main water shut off valve has been turned off. Mainly from the tub\shower faucet, hot or cold water will run naturally and gradually decrease to a pencil-thin stream, without a decrease in temperature, even after 1-2 hours. Occasionally, but not as frequently as the tub, I notice this from the faucet in the kitchen and bathroom sink.
What could the problem be? Where is the water coming from when the main shut off valve has been turned off? If the water is coming from the tank? If that is the case, then why doesn't it happen occasionally and not all the time? I assume, the water heater's tank still contains water even after the main water shut off valve has been turned off.
