Solar hot water system
Yryf
Mar 17, 2016
6
Hi guys
I just wanted to connect my solar hot water system on the roof which has its own tank to fill up my hot water tank inside the house.
So I need some kind of valve to control the flow of water to the tank inside. Only when the water is heated to a certain temperature then I want the water to flow to the inside tank.
Any ideas on the best way to do this?
As far as I know, the solar water heaters are only a passive heating system, and normally does not contain valves, which can explode the unit if the valve doesn't open.
Hi
Yes they are passive. I was thinking two valves just in case. One temperature valve and one pressure valve
