Hello all:
I am a resident of a "luxury condo" two-story apartment building w/two two-story townhouses and about 30 units (Los Angeles), built ca.1985. Townhouses' upper floors are ad-ons which sit on the roof. Month-month tenant; I reside in one of the two townhouses. For more than 6 months I've been asking my landlord to fix the water pressure in my unit. The downstairs portion of the unit suffers tremendous water pressure variation- from a trickle to a hand-stinging deluge- moment to moment; no confirmable pattern; upstairs water not engaged. For that matter, the upstairs water pressure also varies very noticeably. To make matters worse- the adjoining unit is the other townhouse, and it seems to me (from listening) that whenever they use their water, especially their upstairs water, my water pressure suffers. The pressure variation seems to occur most frequently during peak use hours, but other units I've checked don't have any issue EVER.
Finally about 6 weeks ago the landlord sent the bldg plumber (employee of landlord's mgmt co).
The bldg plumber says no one else has complained of any water issues. As noted, I've been to other units while the water in my unit was a trickle and theirs was perfectly fine. I have taken and sent a dozen films showing the issue; the plumber himself has witnessed the dramatic variation in-person. After some unknown repair attempt (conducted while I was at work), the landlord's plumber finally tells me "I'm stumped and have tried everything." I've been asking for two weeks for an update since then with no reply. The municipality is not the issue- again, I witnessed that at least several other units do not have this issue.
How likely is it that the plumber is really "stumped" and cannot even properly diagnose the issue? I know little or nothing about plumbing, but I suspect his claims of frustration are either based in ignorance or are outright lies calculated to protect the landlord's pocketbook. I do know that some plumbing contractors use too-narrow diameter pipes which create flow/pressure problems but I have no training or context to evaluate.
Can anyone weigh-in on this? How complex could it be to Dx a two-story, 30-unit plumbing system with a water flow/pressure issue in one unit? To fix the water flow/pressure in one unit? What tools are available for Dx? What questions should I ask/what would you recommend in general re:getting the landlord to properly fix the issue? While I don't want to get evicted, I do want to get what I'm paying for. Would rather not waste my time in a retaliatory eviction suit but surely will if necessary.
Thank you in advance,
pal
pal
