Just a follow-up question:
When I drained my old heater tank the water just dribbled out. After an hour or so it ran out a bit faster. This was after I had opened the hot water tap that is next to the tank and after I jammed a coat hanger into the drain valve to punch through the accumulated sediment. I also had closed the water shutoff valve on the inlet side.
After I installed my new tank I had to partially drain it too. I turned on the hot water tap as before but when I opened the drain valve, little if any water flowed through the drain hose. Then I loosened the inlet union. I heard a rush of air and what to my surprise, the water flowed out the hose nicely.
I thought that opening a hot water tap would let the air in so the tank would drain quickly. Any ideas why this didn't work as expected???
