I'm having an issue with my kitchen sink. I put meatballs and some cooked spagetti in the drain thru garbage disposal (yes, I know, stupid), and it grinded fine but when I turned the disposal off, the water basically whirlpooled and splashed back up. The disposal is not jammed but water won't drain. If I run the sink it takes very little time for the water to stop going down so I would imagine clog not far at all. Took off cap for trap and let water run out - snaked up thru pipe probably 15 feet and still clogged.
Meet some resistance w/snake but hard to tell if pipe bends behind wall or whatever. Cannot run hot water and let it sit because what happens is it fills in the garbage disposal and the disposal just starts dripping out water under the cabinet. This made me think the clog was within the disposal side even though its spinning and grinding properly. However, if I take the cap off the trap and run the water thru the sink, it comes thru disposal fine and out the trap hole. So that must mean clog is in pipe and not disposal, correct? Wanted to avoid having to call a plumber but not sure what to do. Advice?
