Okay I currently have a gas water heater with a recirculating hot water pump and copper lines throughout. I have 3 bathrooms (2 down & 1 up). The 2 down showers are the only ones with the problem of the shower temp going from hot, cold, scolding hot, cold throughout a shower, without any other water usage going on (flushing toilet, sinks etc).
I took off both bathrooms shower heads and the problem is still there with the water coming straight out the pipe.
The house never had this problem until recently.
Does the hot water recirculating pump thermostat (which is at 140 degrees) and the water heater thermostat have to be synced (temp wise)? The water heater thermostat does not have degrees just letters (Cold, A, B, C , VERY HOT) I have it on "C".
I thought about installing a anti-scald valve but I dont think I need it since This was never a issue before.
The water heater is about 5 years old and I could not find any visible leaks around the heater.
Sorry for the long essay!
Thanks in advance.
Thanks in advance.
