Shower head ball joint.
May 26, 2018
6
Are shower head ball joints all the same size? Universal/standard. Not referring to the coupling that I know is universal/standard 1/2 inch, but the size of the ball itself. Thanks for your help.
The ball is probably not universal. They are all specific to the particular head that goes on it.
Price Pfister used to make an arm that had a ball on the end instead of threads, so you would have to change the arm of find an adapter.
Why do you ask?
  • Like
Reactions: SHR
I am “customizing” a shower head. Want to know if they are interchangeable. Compared two. They appear to be the same size. One chrome, one ABS plastic. It IS the main part of a shower head, regardless of manufacture, design and type. Right, the old shower arm with ball attached. Good that we advanced from that.
I realize that this is an unusual, boring plumbing question. Can anyone provide information about this? Thanks.
Mr_David already gave you your answer. I will reiterate: The "ball" is a integral proprietary part of any shower head and is NOT for use with a different shower head. Whenever a shower head is replaced the entire shower head must be replaced. This includes the half with the ball joint.
SHR. I understand what you are saying. Understand that I have tinkered around with many things, including shower heads for years. Including whether I choose to have the water that I pay for restricted or not. Yep, manufacturers are designing shower heads more “tamper proof” because of gmp “restrictions”. No I don’t reside in California. I am sure the shower head ball joints may be somewhat different in size comparing several different shower heads. My gut tells me that they are probably the same size.
https://www.walmart.com/ip/Lasco-Shower-Arm-Ball-Joint/47661102
Then go with your gut.
You asked " Are shower head ball joints all the same size? Universal/standard? "
NO, they are not.
Some heads may have a common ball size, but the ball size is not a standard
Do you have another question
