Hi there,
As it is almost always the case, for us amateurs, I have a leak in the shower, water in, but it hides from me.
I noticed a leak after about three months after I built the shower and located it where shower arm screws to the in wall brass connector (pic). I attributed the leak to shower arm (10 inch L shape) not being tightened well. Over the next month I tried to use brass pipe extension with coupling for shower arm, good teflon tape, etc. Always leaked, sometimes less, sometimes after a while.
Finally, I sadly proceeded removing the tiles and after that I connected the shower arm, let it run for 15 minutes and NO leak anywhere. I did the plumbing myself, flex pipe. I was surely hoping to see some connection inside of the wall srewed up, but they stayed dry.
Sure, I can re-plumb that part in the wall, but I am not certain.
I have Grohe valve with two outlets (the other one for hand shower is fine), so I eliminate trouble with the valve. Shower is on the second floor, above the garage, and I have an access in the ceiling.
So I thought I will ask, maybe I am missing something, forgetting something, I just dont want to replumb the connector for shower arm.
Pic is the connector in the wall.
Thanks for your thoughts.
