Hi. I started my irigation project today and it has been a long time sense I had glued PVC together and I did it slightly wrong. I primed both the outside of the one end and the inside of the other end, but only put glue on the outside of the one end. For some reason I thought you were supposed to do it so that you didint end up with glue pushed inside your piping. I had a feeling of doubt and when inside and watched a video and the guy on the video put glue both inside and out.
It's 1inch PVC at 60-70psi, right before an automatic valve, so there could be some pressure spikes.
Should I redo it? I will probably be going back into town soon anyway to get more parts.
I still think its a bit wired that you put glue on the inside, cause if you get a little lip of glue sticking up inside the pipe it will slowly break off and could clog things downstream.
Thanks for any advice.
-Adrian
-Adrian
