Jeff Davis
I never have drained it. The recirculation pump uses an Aqua-stat that makes it run about hourly for 5 minutes, depending on the temperature in my garage where it is. Doesn't the recirculation pump keep any sediment stirred up at the bottom, since that's where it puts the water back into the tank at the drainage outlet, so maybe no sediment ever settles & causes a problem with causing hot spots at the bottom of the tank that can turn into leaks?
I've read some different things online that say I should either drain a gallon or two every month or drain the full tank annually. I don't know what I should do if I do anything, especially if a recirculation pump affects needing to this.
Maybe it matters to those of you that know water heaters, mine is a:
Bradford White Model # URG150T6N 50 gallon bought in May 2021 & it has never been drained.
www.bradfordwhite.com
