shaken-n-stirred
Is it true you can only share the lav vent for a toilet? Can not use the vent for a washing machine?
Secondly, is it correct that the toilet has to be the last fixture on the branch line and that means it is the HIGHEST up stream?
If so the lav drain has to enter the branch drain directly down stream from the toilet, correct?
And the lav vent should enter the branch drain at a 45 degree angle or more rather than flat or parallel?
Am I on the right track here?
Thanks to all.
Thanks to all.
