Howdy,
I live in SE Texas near the coast. I recently built a detached garage behind my house. Before we put in the pad for the shop I discussed with my contractor about connecting it into my existing septic
The garage is on the left side of the house, and the septic on the right. He looked at it, and had us build up the pad an additional 2 feet above the house to have enough fall.
At the time the garage was built we just roughed in the drains and left them capped and buried outside.
I am now trying to run the sewer line and I have run into an issue. The drain behind the garage is buried about 4-6" in the ground. The drain comes out of the back of the garage, goes over about 5', makes a 45º turn and then runs across my backyard. When it gets even with the end of the house it makes another 45º turn and turns towards the main drain of the house which empties into my septic system.
I've dug my trench and shot it with a laser last night to set my "level". The total length of the system is 163'. In checking the drop I only have 16.5" of drop from one end to the other. I had planned to use 4" pipe, but the recommend fall is 1/4" to a minimum of 1/8" per foot.
By my calculations I have .083% fall currently 1/12". It looks like I need at least 8" more fall for the total system to even be at the minimum of 1/8" (.125%)
I believe my options to be:
Install a lift pump.
Install a new septic system behind my detached garage
I wanted to see if there were other options I was not considering. I had seen that if I went up to a larger diameter pipe that I could get away with less slope (6" or 8"), but I was concerned that the pipe would then be too large to keep the proper velocity.
Anyway, I'm just looking for options on what would be the best course of action.
Thank you.
Thank you.
