"Hello",
You might want to look into `SANIFLO` Products - Which include `SANIBEST` - These are W.C. Macerators with built in Pumps - Normally used when you would want to Install Bathrooms - Utility Rooms etc. in `Unusual` areas - Basements - Below the Drainage System for example - OR - Roof Extensions/Conversions where the `Soil & Waste Stack` is `Remote` from where the New Sanitary Ware etc. is to be installed.
As these are available throughout the U.K. and Europe - I assume that they are available in the U.S. - ?? - Just one point - The Macerators connect directly to a REAR OUTLET W.C. Pan - Are THOSE available in the U.S. - ??
While these [Various Models] Products are capable of `Pumping Up` - they are also capable of Pumping LONG Distances - Using `Small Bore` Pipe - THIS may solve the Problem of not being able to Cut `Joists` for a 4" Pipe run, Also the `Fall` of the `Outlet Pipe` does not have to be as much as that for a 4" Pipe - because the `Sewage` is being Pumped to the `Stack` OR to the Drain.
They are installed connected to the W.C. - REAR OUTLET Pan - behind it - usually `Boxed In` - I assume that this type of W.C. Pan IS available in the U.S. - ?? Otherwise this `Post` is completely useless !! The waste pipes enter the `Pump Box` via connections - there are `Prescribed` minimum Heights/ `Falls` for the waste pipe runs - There is obviously an `Outlet/Pumped Pipe and the units require an Electrical Supply - Typically `Switched/Fused` external to the Bathroom to comply with Electrical Regulations/Codes.
Because these are `Pumped Macerators` there IS a `Pump Noise` - I wanted to make You aware of this straight away - but I have seen MANY of these installed `near` Bedrooms etc. - where the occupants of the Home did not seem to be `bothered` by the Pump sounds.
I would advise - If possible that You visit a Bathroom/Plumbers Merchants where one of the Saniflo Products is installed in the `Showroom` - to Hear the Pump Sound for Yourself - prior to deciding on installing them at Home.
It may be possible for You to Install the smaller pipework either `Under Floor` or perhaps a route could be found where the pipework is `Boxed in` ??
Something that is VITAL is that You obtain [Download ?] the Manufacturers Installation Instructions - As although these `Pumped Macerators` can `Work Wonders` - there are LIMITATIONS to what You can and cannot do with the Pipework.
You MUST be completely Familiar with these BEFORE deciding to Purchase/Install - One Error in the installation can mean that NOTHING gets `Pumped Away` - BUT `Correctly Installed` they enable one to Install Bathrooms, Shower Rooms, Utility Rooms etc. in places where NO other method of `Drainage` is possible.
Here in the U.K. the `Sanitary Regulations` quite correctly state that you cannot use these Macerators/Pumps for your `Primary` W.C. - As in the event of a `Breakdown` or Power Cut - you MUST NOT be relying on a Macerator W.C.
Obviously that is NOT a consideration for your Home - as You have another W.C. - in the event of such an occurrence.
What I would advise is that You check that these Products are `Allowed` by the Codes in Your Location - Local Authority.
I would also suggest that You give copies of the Installation Instructions etc. to your Plumber - Who MAY `notice` something that means that You cannot Install these Units at your Home - It is well worth a `Detailed Survey` of the requirements and the `Proposed Works` to ENSURE that these Units ARE `Suitable`.
I obviously cannot state that You will be able to use these Units - They are just a suggestion of something that MAY be suitable - If NOT - I cannot see another way to Install your proposed Bathrooms as You are `Restricted` by the Construction of your Home and of those Homes around You.
There are a number of Models shown on the website - you can select from the range by what you want to connect to the Saniflo - and what you want to achieve with the `Waste` - regarding `Pumping Up` - or Pumping Horizontally - large distance [ I think over 120 Feet ?] - BUT - As I mentioned - You MUST ensure that You select the correct Product AND [Download ?] Read the Manufacturers Installation Instructions - `Cover to Cover` - Please make sure that You CAN achieve what the Instructions state - As an Error could make the whole Installation of the Bathrooms and Saniflo Pumped Macerators - `USELESS` !!
"Please don`t take offence" - I want You to be `Fully Informed` that these Products MUST be Installed Correctly - The last thing that I want to do is to `Recommend` a Product - You purchase them - One for EACH Bathroom that has a W.C. - They somehow get installed incorrectly [not hard to do !] - The Bathrooms are installed - NOW the WHOLE JOB is `No Good` !!
I would be interested as to whether these Saniflo Products are `Suitable` for Your situation - perhaps You could `Post` a reply on here - "Thanks".
"Regards",
CHRISM.
P.S. "Sorry" to those of you who dislike my `Wall of Text` Posts - I HAD to ensure that the `CORRECT` Product Installation was `EMPHASISED` - And I wanted to describe these Products - So that this Post was `Informative` - I hope.
