Hello,
I am new to this forum and have a real problem. I purchased a home and we recently noticed that in two bathrooms at separate ends of the house that sewer gas seems to be coming in thru the sinks. The sinks all have P traps and drain normally when filled. I went under the house and had my wife flush the toilet, while I held my hand around the sink drain pipe. It felt like the 3" toilet pipe to the 3" main drain was forming a suction or vacum as the water from the toilet rushed down the main drain. I think the suction is removing the water from the sink P trap, enabling septic tank gas to flow up thru the sink drains.
Both sinks have a 1/12" drain that are glued to multiple ABS pieces that connect under the house to a 2" drain, which connects to the 3" main drain. I checked the vents ion the roof and they appear to be open and have sewer gas coming out of them as well. Is it feasible to install an Air Admittance Valve under each sink and thereby alleviate this problem?
I have no idea if the involved sinks are connected to the vent stack system and did not want to tear my walls apart to determine that answer. Can an AAV be installed when an existing vent stack is in place? I live in California, which may or may not have some codes that "normal" States do not concern themselves with.
Any help here is deeply appreciated. I know this is dangerous and I am concerned for the health of my family.
