poobucket2015
Hi, I have a sewage ejector in the basement and lately the toilet paper from the basement toilet has started to hold the float down and cause it to overflow.
The pump has a metal u bar above the float and the float is attached at the top and bottom so its not on a tether. Sort of like a lever and what is happening is the TP stacks on top of the float preventing it form lifting. The drain pipe from the basement bathroom sits directly above the pump and is aimed in a way that tp shoots out of it on top of the float.
I can't turn the pump without rerouting the vent and sewage drain line and am looking for the path of least resistance here.
This is my setup:
is there a better pump that doesn't use that type of float? IE one on a tether instead?
Any thoughts?
This is my setup:
Any thoughts?
