kingkohlmn
Hello,
First time posting, new member. I have several questions about a home we recently purchased. Not all are related to the septic. This is the first time I own a home with a septic system. Home was build in 1998. The tank was inspected and pumped. All is good with the tank. The previous owner recommend once a month to pour a packet of yeast into the toilet and let sit overnight than flush. Home is located in Marble Falls area of Texas.
- Is it ok to use a water softener since the water will go into the tank? The dishwasher and refrigerator appear to be on the newer side. The inside of the DW is coated/stained with white. The ice dispenser also have a build of the white material. Assuming this is hard water. We are having the water tested.
- Will be replacing the electric water heater. It works, but the previous owner does not know how old it is and I could not find any date on the tank or labels. I am thinking of replacing it with a tank-less system. Will take up less room and from what I have read will save some money in the long haul.
- Is it ok to use a water softener with a tank-less system?
- Or should I consider using a reverse osmosis system? I did a google search and found conflicting information. No RO should not be used with a tank-less system and yes it can be used.
- Or should I consider going with a softener and a whole house filtration system. I believe they have 3 filters in line, not sure.
