I haven’t noticed any sediment in the cold water. My toilet water has been discolored and I’ve flushed the water heater tank a dozen times and still picking up sediment. Is it probably coming from the city lines?If they’re the cause of the sediment or whatever then there’s not much you can do other than filter the water.
If it’s coming out of your water heater you could try to flush it out but you could also just replace it.
Does your cold water have any problems with “ sediment “ ?
Water heater is from 2016. Sediment isn’t the problem but my shower water has been rusty, but conflicted if that because of the water heater or the city.How old is the heater ? Is this sediment causing any problems ?
I have noticed my indoor sinks using only cold water haven’t been discolored as much but still have a Metallic taste to itDo you have neighbors ? Ask them if they’re getting the same.
Do you use all of your hot water supply or close to it on a regular basis ? In other words do you use a lot of hot water in a short period of time.
Run a lot of cold water into the bathtub and see what it looks like. You could even do this outside at a hose Bibb with a 5gal bucket.
I flushed it about a dozen times today and got a lot of small sediment out. After showering tonight I noticed the water wasn’t as brown but still had a pretty heavy iron smell to itIf a water heater has never been “ flushed “ and it’s out of warranty, I don’t recommend disturbing the tank.
Sometimes rusty water gets stirred up and never clears up.,
And again ... we agree to disagree. With an Electric you can easily vacuum out the sediment ... add a little water ... vacuum that out ........ and after about 3 or 4 times the tank and water is reasonably clear. And I won't even bring up the Anode topic.
I also replaced the anode rod a couple weeks ago when all these problems started
Here we go again ....... that's why Erath is commended for changing his Anode rod.That doesn’t cure a rusty tank does it ?
You can drain and vacuum all day but if the inside of the tank is rusty you’re done.
Then you tell me why he’s still getting rusty water......
Oh.....oh yeah......he’s been tinkering with his water heater. That’s why he has rusty water. He’s disturbed it.,
It may not ever clear up. This isn’t my first rodeo.
