realmswalker
Hello everyone,
I am going to run hot and cold water lines from outside, underground to a garage for a washer.
I live in southern California so there is no frost line or frozen pipes to worry about. it's about a 6 foot run from the pipe straight down into the ground, then a 23 foot run, and another 6 feet at a 90 degree turn.
the pipes will be buried about 18 inches down.
Is there a better alternative than copper? something that can use shark bite or other types of fitting without soldering.
Thank you.
Thank you.
