im1dermike
I'm looking to install a water softener to deal with the hard water in my area (15 gpg). The model I've honed in on is the GE GXSH40V 40,2000 grain softener (here is the install guide). I'm planning out the project and have a question about the transition of pipe to the water softener.
The water softener comes with a single bypass valve which has 1” NPTM threaded connections for the incoming and outgoing plumbing. The water pipe coming into my house is 3/4". There is about 10' of that pipe until it gets reduced to 5/8" right before it goes into a (the water company's?) meter. Out of the meter it's again reduced to 1/2" copper pipe which is what is run throughout my house.
The install guide has the following notes:
What I'd like to understand if there would be any unacceptable impacts on water pressure or otherwise going from 1/2" to 1" "immediately" at the softener which would suggest an alternative plan.
- Pipe fittings must be 1/2" minimum.
- The water softener requires a minimum water flow of 3 gallons per minute at the inlet. Maximum allowable inlet water pressure is 125 psi. If daytime pressure is over 80 psi, nighttime pressure may exceed the maximum.
