Betadine
I recently had a plumber reroute our pipes because of a slab leak. After the job was done we noticed that our water pressure was 100psi. The plumber said we need to change the pressure regulator valve. We have a Watts N35B which is obsolete. The pressure for this valve is 25 to 75psi. The plumber said that the high pressure was the reason for the slab leak. He offered to change it for $400. A second plumber told me that the pressure was not an issue. Copper pipes should handle pressures up to 200psi. He said the leak was caused by something in he ground like a rock against the pipe. Who's right?
