colvosview
I have a unit manufactured in 2015 on which the pilot goes out randomly, after working fine for a few days or a few weeks. It has exhibited this problem since it was installed, but for reasons I won't go into, it hasn't reached the top of my "to do" list until now. I don't have experience in this area, but am a reasonable skilled DIY guy. I thought the problem was probably a bad thermopile, which I should be able to replace myself. When I looked for videos to show how to do this, I saw one showing how to test the thermopile, which seemed worth doing before I just replaced it. The test I saw involved pulling off the thermopile connector and bridging the connector with the probes of a multimeter, then lighting the pilot to see if/how much the current increases. I watched the current read out until it got to 650mA, and it was still slowly climbing, so I think the part is OK.
The video technician advised that if the part passed this test, the problem is likely either the thermal cut off switch or the gas control valve. Since I cannot spot anything on this unit that looks like the cut off switches shown on various videos, I'm guessing that that function must be incorporated into the Honeywell gas valve controller, which means that it must be replaced. I thought I would seek advice and/or confirmation before purchasing this somewhat pricey part.
Any words of wisdom from a more experienced practicioner are appreciated!
