Hey guys wondering if anyone can give some advice. I recently completed a new boiler install (wm97+ with companion water heater) and in the process relocated the boiler which involved repiping domestic water lines. Now after the install Im getting a reverse water hammer when toilets are flushed and when the washing machine turns on. Also getting hammer when I turn on outside house bib. The reverse hammer consists of only one loud bang when during turn on not valve closing. If I turn on basement sink hot water and flush toilet no bang, if I turn valves down on toilets on washer almost to off no bang. I have air chambers installed at the washer and a shock arrestor where the bang is loudest in domestic cold pipe but neither seem to help at all. My question is do you think adding an expansion tank to cold water domestic would help? Would I benefit from installing a vacuum breaker? Static pressure at outside house bib is only 50psi. Everytime I turn on washer or flush toilet following the reverse water hammer I get a single drop of water from the vent of my back flow preventer on boiler fill line. Any ideas? Thanks a bunch in advance.
