I want to install a reverse osmosis system. Seems like a DIY project I should be able to do. One thing I can't figure out is what kind of adapter I need to purchase for my ice maker line. As you can see below my ice maker line (white) is ran with a standard water line from the cold water. I know the standard connectors with the RO will not work. Is there a an connector that RO piping can push into and go into the white connector which I'm guessing is 3/8"?
Another note the RO comes with adapter to use the same line as the faucet. Since my shut off value has two outlets is there an adapter once again for the RO line or should I just change the shut off to a single?
Greatly appreciate your time.
