RyanOneill
Hey Everyone, I have quite the project going on at my house right now. I'm currently replacing all the 45 year old copper lines since I completely demolished the basement apartment and it was out in the open. Every time I touched a pipe a joint leaked =(
I want to switch over to a home run system instead of the current trunk and branch. I do not like them. The plan is to rebuild the basement apartment and give it it's own hot water heater/manifold system. I will be supplying 2 bathrooms and 2 kitchens total. Small home.
My main water supply is only 1/2" but has 80psi. One day I will get it replaced to 3/4" but not today. Can't afford that bill with the rest of the renovations. For the time being, can I jump up to 3/4" after my main shutoff and supply the manifolds with that? I'm hoping there will be enough flow/pressure.
Also not sure how I should split the water supply between the main house and apartment. Should I run a T after the main shutoff and split into 2 manifolds, one for each unit, or supply the apartment from the main units cold water manifold?
Quite alot to read, I get that.. sorry =) . I've done alot of DIY plumbing stuff in the past, but thats mainly just replacing other people's work. Never had to think about proper supply distribution.
I really appreciate anyone who takes the time to read this and gives their input. Thank you so much!
