azt
Hi,
My home water pressure has been fluctuating (but generally has become low/weak) and I believe this 15 year old Wilkins 3/4" BR4 pressure reducing valve is likely the culprit. I obtained what I believe is the direct replacement (3/4" now Wilkins model NR3XL as pictured) and have basic mechanical skills but not much plumbing experience. If the current valve had been installed with double union connectors on each end like I see in videos, I probably wouldn't have needed to post this! But as you can see it has small sections of pipe threaded into it, so I would greatly appreciate hearing the recommended order of steps to replace this (and if I can easily do this via adjustable wrench and some plumbing tape - or should just call an expert).
So I assume (after shutting the water valve behind it and opening a faucet to deplete the pressure) I have to disconnect the pipe further down on either end via one of those large nuts, in order to twist out 1 of the pipe sections from the valve first (or twist the whole valve off the other pipe - I think if i remove the black housing of the existing valve there is room to rotate it off). What is that copper wire going through the left nut for? And once I disconnect I'm not sure how to brace or tightly hold the pipe section I need to turn out of the regulator without damaging it.
Any tips are welcome, thank you!
