replacing ch programmer with two light switches
reddwarf4ever
May 15, 2016
6
as I leave my ch and HW on ON all the time and do not use any timing, could I replace it with two light switches.....
thanks
You need to be more specific. Depends on what it is you are switching on/off.
a pump?
a heaters main power?
a thermostat?
What is a ch?
I have a CH programmer, to set times heating and hot water, but as I never use the timed functions and leave both set to on, then wonders if a light switch ( 5amps I believe ) would be suitable for each service....
If you are installing the switches to control the same circuit that the timers turn on/off, then I see no reason why you couldn't install a manual switches to do the same thing the timers would do.
I can't any reason either, as far as I can make out a CH programmer opens closes a switch wire, don't think it's a double pole switch, so a simple light switch should do. just wasn't sure what current, if any the programmer switches.
