PTNL
I have an outdoor frost free spigot on my 35 year old house, which is now leaking water from the handle. It also does not completely tighten and shut off, there is always a very subtle drip.
I've taken the stem out, and it looks like there is a crack near the internal screw head. Taking the part around to a few local plumbing supply shops, they were not able to identify the vendor or a replacement. An additional curveball is that the previous (original) home owners finished part of the basement, and the part of the hydrant that would be visible inside the house is sadly blocked in a corner by 2x4 studs on two sides, and concrete walls on the other two sides. So replacing the hydrant is a lot more involved than I would prefer.
Ideally, I would like to track down a replacement stem (even if it involves buying the entire spigot), and using the existing spigot casing. If that's not possible, then obviously my next step is to hire a person to replace the hydrant and do a minor re-routing of copper pipe in the wall.
I am certainly not a plumber, so feel free to bounce any questions or clarifications you can think of. I've attached all of the pictures I have of the stem and the exterior portion of the spigot.
