While replacing a vanity faucet this weekend, I found that the drain pipe going into the stub-out does not have the raised lip that helps lock it into the p-trap. Please see the pictures below, and sorry if my terminology is not correct.
This is a 35 year-old house in Cobb County GA, and no doubt this wasn't code. I'm guessing the previous owner must have cut the head off that pipe for whatever reason. As long as I'm doing this, I'd rather do it correctly. It appears that the drain pipe is glued into the stub-out and I can't see any way to get it out to replace with a proper pipe.
While searching for answers, I found two things, but they might be overkill for this project: a PVC Fitting Saver and a RamBit. Looks like I would cut the drain pipe off at the end of the stub-out, then use one of those tools to ream out whats left, just enough to glue in the proper drain pipe.
Am I on the right track here, or am I missing something obvious?
