Hi - new here and redoing a basement bathroom. In trying to replace the trap, threads broke off inside the cast iron t inside the wall. I removed drywall and though I can't measure perfectly - I believe it's 1 1/2" (~ 1 3/4" od) galvanized drain - from my kitchen sink upstairs. My plan is to cut the pipe above and below the t and then replace using Fernco's and a new t. I'm just unsure what to replace with. Use the same stuff (galv and cast iron) or go to pvc?
