Replace bathtub with double vanity
woolybear
Aug 26, 2013
5
Hi,
I want to replace a free standing bathtub with a double vanity. I am assuming the bathtub has a p-trap under the concrete floor. Can I put in a p-trap for the wash bowls without causing problems? I thought maybe a AAV vent between the two traps might be ok.
Any other suggestions?
or... perhaps I could use the underfloor trap. Is there a limit to the tail pipe length (drop) before the p-trap?
Hoping for help.
You can't use the tub trap it would be too far below the new sinks. There should be a vent for the tub that you may be able to use for the sinks.
Thanks John
I can't locate a vent for the tub. The floor is concrete and the walls double brick. Was hoping for a solution without digging up the floor.
Is the idea of an aav between the traps a none starter? Figured it would alleviate any siphon effects.
Thanks phishfood. I guess it's going to be a more difficult job than I'd hoped.
