My first post on the forum and I'm desperate for help with this one. We are moving into a new townhome built buy what we thought was a reputable builder. The kitchen is roughed in for a waste disposal with a switch and plug in the cabinet under the sink. I have installed several disposals in the past and it's not a difficult job. In trying to remove the old drain on the stainless steel sink I discovered that the drain was installed using silicone rather than plumbers putty.
I have tried to put pressure on the drain from the bottom to see if it will release but no luck. The bottom of the sink begins to flex up it's attached that well.
My only thought at this point is to use a bottle jack from the bottom to put pressure on the drain and heat the drain assembly with a torch to see if that will release it from the stainless sink. My concern is getting the sink hot as well and discoloring the stainless.
Would any of the chemical silicon removers penetrate the seal between the sink and drain without harming the stainless?
Thanks for your help with this one
Bob
Bob
