I’ve got a rear toilet I’m installing. There is only roughly 3 1/4” height to the center of the drain from the finished floor. This toilet (Yorkville Vormax) says 4” is needed.
I’m thinking (and desperately hoping) that I’m okay to install as is (with a neoprene gasket) and it would still be okay, since the rear drain on the toilet is 2” Anyone have thoughts or experience with this? I simulated where the gasket can be while still in contact with the flange and sealed in the second picture. You can see that the rear toilet drain is about 1/16” too high or so. Worse case, can I cut out some more room in the middle of the gasket? Big thanks!
