it isnt vented properly.If it's sloped and vented properly the tub isnt going to drain into your 3" combo. One thing I'm wondering though....if that tee goes to the tub, where's the trap?
Thank you for the feedback! Would have made more sense to move the trunk like you said into the next bay so I would be directly under the WC. The tub is vented with it's own 1 1/2" line which is beyond the blocking (see revised attached picture).
you are useing a tee, it has to be a combo, and minimum size vent for a terlet is 2". 1 1/2 is against code
also,,,you can not have 1 1/2 as a vent below the flood leval rim.
on the tub all underflor vents shall be 2"
where is the lav draining to???
