Finishing basement. Two water pipes 10.5 feet long running side by side are attached to the bottom of 11 joists which run perpendicular to the water pipes. Can leave pipes alone and frame around. Or cut holes through the 11 joists and raise the pipes so the new ceiling will be one flat uniform surface. Bottom of one duct is two inches above the bottom of a nearby joist so the holes for the pipes would be made within the bottom two inches of the joist. The joists are all 9.5" long.
Would you keep the pipes where they are and frame around them or cut the joists and move the pipes up? Not sure if cutting the joists is normal procedure or not. Thanks!
