Hi,
I'm trying to install a reverse osmosis kit, specifically the drain pipe part.
The old kit already has a 3/8" draining outlet installed. The outlet is a quick connect. It used to have a 3/8" plastic pipe running into it.
The new kit has a 1/4" plastic drain pipe.
I wanted to leave the old 3/8" drain outlet in place. I was thinking I could leave a bit of the old 3/8" as-is, then connect the new 1/4" pipe into it using another quick connect that converts between the two sizes.
I believe this is what I need:
http://www.homedepot.com/p/3-8-in-x...PIPHorizontal1_rr-_-204464263-_-100144498-_-N
Does this sound right, or am I looking for some other sort of connector?
Thanks
Thanks
