RinOakland
Hi, I’m running 3/4” black pipe for a gas grill and had three questions:
1. The indoor portion of the run is literally a straight line that follows a joist. Is it better to attach the pipe to the bottom of the joist, or the side of the joist? The latter seemed safer (i.e., not as exposed/susceptible to getting bumped), but I wasn’t sure.
2. What type of hanger would you suggest? I’m in a seismically-active area so I want something that can move a bit if there’s an earthquake. I’d also prefer something a little more substantial to plumber’s tape.
3. Once outside, the pipe needs to turn 90 degrees up and poke up through a wood deck where the grill sits. Should the pipe be attached to the deck itself in some way? If not, the only thing holding the pipe steady would be the last hanger in the run. I didn’t know if there were any fittings that attach to the floor of a deck to hold the pipe, or if you just cut a hole in the deck and run the pipe up through it?
Thanks so much for your thoughts.
