jpokerwinski
I have a shower I am moving and the shower (2" pipe) is about 10 feet from the vent. Is this adequate, I know it is close to the max distance.
Jim
Jim
I get different opinions from even licensed plumbers. But 1/4 per foot you can’t go wrong
Totally agree that 1/4" /ft slope is what is required, however, as the plumbers know, at a distance of 8 ft plus, you lose the venting capability since the amount of slope starts exceeding the diameter of the pipe.
I agree that the scouring action provided by the 1/4" is more important(in this case), however, I thought there may be an exception for the maximum distance for a tub or shower, for a single bathroom. In other words a wet vent. Is this true?
I thought I saw it in one of the codes but can't seem to find it.
No...2" drain exceeding the 8 ft requirement.ahhhhh..took me a minute to figure out what you are asking
you are asking if a 3'' pipe can be used instead of a 2'' pipe for the shower at a 1/8'' pitch
i would say yes, but, doesn't the code restrict the size of tap?
