PVC Sink Drain Pipe Leak Where It Goes Into Trap
JIMMIEM
Supporting Member
Aug 9, 2014
193
18
The kitchen sink drain pipe has a leak where it is joined to the trap. What is the best way to seal the leak? I've seen those PVC joint rings on Youtube videos. Is this a good way to fix the leak?
Thank You
Post a good picture or two of the leaky joint.
What material is your trap and drain?
You might just need to tighten the slip nuts.
Or replace a damaged or crumbling washer.
